Spanner kits
Neeves
20 Nov 2011
Sydney, Australia.
I, very recently, bought and received some of these 'things', they are multiple spanner kits. I've put shrink covers on the handles.
Mine came as a set of 4 and I bought the 'silver' one as an extra.
The top one is 5mm thick and is said to be made from chrome vanadium (but how would I know?).
I've not tried them in anger but they seem to do what it says on the box. Oddly they come in Imperial sizes.
The top 4 pieces cover the exact same sized nuts, or bolts, the long one allows more tension the short one works in tighter spaces (and the little black on is for smaller bolts).
The silver one is simply a variation on the theme.
They would 'make' a shackle key
They are as cheap as chips from Time and seem to offer an alternative to a heavy spanner set.
https://www.temu.com/ul/kuiper/un9....MI0q2v8-j1jQMVatMWBR2Slx82EAQYASABEgK89_D_BwE
Jonathan
Can you put a set of spanners in your pocket? (admitting these things don't fit monster bolts)
I'm not recomending them, I've said I'veonlyjust received them.
I'm pointing out they are available and one tool is significantly lighter than a spanner set (I know I have spanner sets :) ).
Jonathan
Jonathan
Over the years I've had (been given) various "handy" or "clever" or "cost-saving" tools claiming to be spanner replacements - not one of them has ever worked in real life.
These for instance only work on 3/6 sides, and then only if you push/pull against the tendency to move to the wider part. Save yourself some grief and file them under "b" before they damage something.
I carry spanners, 8 - 22mm, but have one of these
for the bigger stuff, especially the prop nut. I've no argument that the best spanner for any job is the right sized ring or socket and 2nd best is the right sized open-ended, but I reckon that the bad rep adjustable spanners get is from poor quality ones being used incompetently. Slip it on a bit loose, and it will grip until you have to lean, then, with a cheap one, the jaws will spread, almost guaranteeing it will slip and take the corners off the nut. Even with a good one, it's putting the strain on the wrong part of the nut, making a slip more likely.
I also have a set of "fits all" spanners, but I think I've used them twice in the 10 years since I bought them, and only because Neptune nicked the right spanner.
I've never seen those tools, Jonathan, but as others have said, a decent quality adjustable spanner (Bahco, SnapOn) is a handy thing to have. I have a set of metric combinations spanners on the boat but sometimes need another eg to hold a bolt head while turning the nut on the other end of it. That's when an adjustable comes in handy.
