gtmoore
I'd like to use my heads compartment for showering and, notwithstanding the issues of hot and cold pressurised water that I don't have, the bilge on my Moody is very shallow so it would be impossible to get a shower sump installed below the floor. I had thought of just letting the water run into the bilge and let the electric bilge pump deal with it but the holes that run through the bearers are extremely small and get easily blocked.
I wondered could I pipe a plughole fitting straight to an electric diaphragm pump? Do I actually need a sump? The Whale type ones can run dry and are suited to pumping shower and waste water so it would just be an issue of switching on before stepping in and switching off when you've finished.
Is there anything wrong with my reasoning here?
Gavin
Gavin
