Birdseye
Well you are a group of sail tweakers arent you?
Coming back across the channel yesterday ( Bristol that is not the soft southern version) I was a bit surprised to find myself with far more rudder on than my failing memory suggests I should have had. But I am a bit rusty having spent the last summer ( wasted should be the word) on home improvements not sailing and the previous winter out of the water.
The boat is a Starlight 35 which is masthead rig and medium displacement. Barn door rudder so it has never rounded up even once. Anyway, the windex indicated 20kn on the beam. I had one reef in the main and one in the nice new laminate genoa. The log isnt installed but the gps was showing 7.5 to 8kn. I was mostly cross tide but possibly getting a bit of tidal help.
The pilot was doing a good job but the wheel angle was 45 to 90 degrees so had I not been single handed I would have put in another reef. Yet I remember racing the boat 2 years ago in such conditions with just one reef in the main and none in the genoa.
Lots of backstay tension on. Main well down the track and sheet out to the point where it bubbles behind the mast.
Any ideas? I suppose the windex could be under reading but no reason to suspect that. What else could it be?
