LittleSister
Lots of good advice above.
One additional thing I'd emphasise is that a boat isn't like a car. It's comprised of dozens (hundreds?) of different little systems/bits of gadgetry/bodges made/installed by different people at different times, any of which can, and from time to time will, go wrong or not work work as you expect.
You can't just hop in a boat that's a few years old and new to you, and expect it all to work perfectly so you can drive off to the other end of the country (particularly so if you are new to the game and don't have the experience to know what 'correct' looks like, or know work-arounds to cope with things getting stuck or failing.) You might possibly be lucky, but you need to know whether it's all working - or more realistically, how well it's all working - and you know how to work it, before you set off.
I'd therefore
- recommend that when you get a boat, you spend at the very least a week doing day sails from where the boat is when you buy it, to get used to it and find out what works (or how much it works) and what doesn't. That will be both fun and very productive. (don't see it as an impediment).
-strongly caution against attempting a single-handed delivery trip from the south-coast to the north-west until you are significantly more experienced. Organising crew will be a bit of a challenge (you can put an ad on the 'crew wanted' part of this forum), but you will likely be much safer and have more fun - much less stressed, much less tired, and you'll have several heads and more experience to cope with challenges (and you are almost bound to have some). You will also learn from your companions.
Happy sailing!
I'd therefore
Happy sailing!
