I didn't want to divert the thread on sprayhood canvas so....Has anyone made a solid sprayhood/dodger/cuddy - call it what you like.
TimBennet posted "... you can make the sprayhood (at least) out of GRP or aluminium. Replicating the panel lay out from a canvas one makes them the most aesthetically pleasing (IMHO), although with more flat areas like the Halberg Rassey ones, allow you to use real glass which increases their hassle free longevity even further."
I wondered if anyone had tried this, and with what success? If so, how did you do it? And if you haven't done it, how would you go about it?
Bobc
The only thing is I would put ply around the windows so that I can bolt the windows in if you wanted to.
Bobc
I've done lots of fiber-glassing and I'll go along with what you saying: my approach will be similar. The structure you are suggesting would be light and stiff. I'd give special attention to how it was attached to the coach-house as I would want it to detach without doing doing damage in the event the yacht taking a freak wave over the deck. The only thing is I would put ply around the windows so that I can bolt the windows in if you wanted to.
I have read that if you want to sail in tropical/hot climates the dodger needs ventilation at the front and the top otherwise it becomes intolerably hot. (I have two Houdini hatches (500mm X 500mm) spare so I'll put use them)
https://www.google.com.au/search?q=...a=X&ei=QXRyVMafM8bsmAWcjoGoBQ&ved=0CAYQ_AUoAQ
https://www.google.com.au/search?q=...d=0CAYQ_AUoAQ#tbm=isch&q=solid+yacht+dodgers+
https://www.google.com.au/search?q=...UoAQ#tbm=isch&q=canvas+yacht+dodgers&imgdii=_
Here is an article on a home built solid fiber glass sandwich dodger. Mine will be similar but will have 3 "windows" across the front (the middle one being an opening hatch). Note the provision above for a small ventilation hatch.
A Homebuilt Hard Dodger For New Zealand Sailboat Mai Tai
by John on June 20, 2008
http://www.morganscloud.com/2008/06/20/homebuilt-hard-dodger/
Bobc
You obviously have "been there/done that". What are your thoughts about fixing it to the deck/coach house?
Who was talking about a cored dodger? I suggested making a female MDF mould and laying up inside that. To give strength you would glass in foam ribs. It would be much easier to end up with a smooth finish that way. It is the way this wheelhouse has been made: http://www.worldseafishing.com/forums/threads/new-project.1976015/page-113
I was thinking along those lines.. Solar panel on a solid top.I've sailed a few times on a Contest, with solid windscreen, canvas sides and top..
Seemed a good compromise to me.
see post #50.
Doesn't anyone sail with their sprayhood folded down on nice days? Bit like owning a convertible sports car and never lowering the roof. Solid dogers are for sissies who secretly hanker for a MoBo.![]()
