oldvarnish
Both the two I've seen were made by returning circumnavigators.
Both had done the same using the sprayhood frame and clothing it in thin ply as a former and then GRPolyester with gel coat on the outside, To ensure fairness of the gel-coat they'd used cling film.
One was on a Rival 36, the other a hard chine steel boat, both improved the look of the boat and both had multiple curves as one would expect from a canvas sprayhood.
V interesting. Hadn't thought of using the existing frame as a former.
Never done this, so I'm guessing here (advice from a GRP worker would be helpful)..... you'd 'wrap' the existing frame in thin, bendy ply panels which you would tack together temporarily with tape?
What's the next step? Do you them cover the outside with GRP, then gelcoat. You now have a solid structure( when it's dry). Then remove it from the frame and cover the inside with GRP and gelcoat?
Is that how you would do it?
Is ply the best stuff to make the core?
