Sailing newbie selsey
Can I please ask for some advice, I am looking to add some solar panels to my boat, I have had her for a year and last year on the swing mooring the batteries did not get a full charge, hence the addition of solar for this coming season. I plan to renew and update navigation, radar AIS etc over the next couple of years, so although the solar i am thinking of adding will be an overkill for the systems currently, I am thinking you can never have too much power.
I have two batteries onboard a starter battery at 85ah and a house battery at 105ah. They are on a three way switch and independent of each other.
I plan to install two 100w panels in parallel which are these
https://www.amazon.co.uk/Reno.../dp/B07HR6RSB9/ref=sr_1_1...
As far as controllers I am looking at this dual battery MPPT contoller https://www.photonicuniverse.com/.../648-High-efficiency...
my question is what gauge wire do I need from panels to controller, looking at using Y connectors to wire them in parallel. Also what wire guage from contoller to each battery?
my second question is I want to put an inline fuse between positive terminal of each battery and the MPPT controller is this suitable and if so what size fuse should i use? https://www.amazon.co.uk/All.../dp/B00904N85G/ref=sr_1_3...
would the same inline fuse work in the postive cable after parallel conection is made from panels going to the controller this will enable me to isolate the panels if needed, what fuse would you recommend for this one?
many thanks in advance
