mikedw
Active Member
I would like to fit a solar regulator with a low voltage load disconnect to protect the house battery. I found a circuit diagram for a Morningstar Sunsaver regulator and the Low Voltage Disconnect is only on the positive - the negative is straight from the battery.
On my boat (Dehler 28s) the main switch for the house battery is on the negative, and the main fuse (35A) on the positive near the battery (10mm2 cable before, 6mm2 cable after).
At the switchboard by the chart table there is;
D: Direct negative (VHF, Shorepower charger, Diesel Heating),
-: Switched Negative (used for everything else),
+: Direct positive (VHF, Shorepower charger, Diesel Heating) and
2-20: all the individual switches for lights etc switched on the +ve side from the direct +ve feed.
I wonder how/where I should best make the alterations/ connections for the Load connection/Disconnect on the solar regulator bearing in mind it's the +ve that's switched on the regulator but negative that's switched on the boat.
I can't just move the +ve from battery to solar regulator as shore power charging etc uses it. The switchboard is on the other side of the boat from the batteries.
The only possibility I can see at the moment is running a second +ve feed from the regulator to the switch panel and splitting out the positive in the panel between what is always on (shorepower charger etc) and disconnectable.
Anyone any ideas / suggestions / help?
Here's the electrical plan which may be clearer than my description:
Hauptshalter Verbraucher = Main Switch - house battery
Efen Sicherung = Main +ve fuse (35A)
Ladegerät = Shore power charger
UKW = VHF
Heizung = Heating (Eberspächer)
UKW = VHF
