Nicholas123
N/A
The wiring of auto bilge pumps is an ongoing debate. Some say this should be wired direct to the batteries. If your boat develops a leak whilst you're away, you'd probably want your bilge pump to keep the water out. Better a flat battery than a sunken boat!
On the other hand, some bilge pumps (well, the switches in them) seem to use a sizeable (in the long term) amount of power checking to see if there is water about, so could potentially flatten a battery even if there's no water about.
If you have a solar panel keeping things topped up, it could be a good idea to have the bilge pump wired up direct, I guess.
That's precisely the situation I face.The drain from the automatic bilge pump was possibly negating any benefit from the solar panel & I'm not sure that an automatic bilge pump is all that useful.I visit the boat almost daily so am on top of small leaks.A situation where the bilge pump would be useful would have to be catastrophic & would drain the batteries in only a few hours anyway.Certainly overnight when I could'nt do anything about it so what use would it be!
