mark1882
Hi How big an issue is shading of solar panels I have some heard some people say that only 10% shading can knock out a whole panel
I am in the process of fitting 2 x 80w solar panels on a gantry and have been reading some conflicting opinions about the impact on the performance on the panels of shading. I am also planning to fit a wind generator and numerous antenna including Wifi Bat, Navtex, Weatheman and GPS which will on a bar as part of the gantry that is upstanding at the rear of the gantry which means that when the sun is from the stern they will cast a shadow,albeit small over the solar panels. The 25mm upstand will run the full length of the panels so could potentially cast a small thin shadow over the length of the panels. The panels are polychristaline
I am not sure if this is going to be an issue or not and if it is i may need to redesign the gantry.
Any advice about how much shading is an issues on the performance od solar panels would be appreciated.
Many thanks
Mark
Many thanks
Mark
