BabaYaga
I partly renewed the solar set up on my 29 foot sailing boat at the beginning of this season. As I am not convinced that I am getting best possible yield, I would be grateful for some advice.
This is what I have:
On the hatch garage is a (new) 45 W panel which is permanently connected. It has 39 cells and the values are as follows: Maximum current (Imax) 2.10 A, maximum voltage (Umax) 21.43 V, voltage open circuit (Uoc) 26.5 V and short circuit current (Isc) 2.17 A.
I also have two foldable 50 W panels which only come out when the boat is used, generally when at anchor or moored. They each consist of four small interconnected panels in a fabric ‘briefcase’. I have had these for a few years. The specification I can find for them gives only the following values: Maximum current 2.78 A, maximum voltage 18 V.
So 145 W of solar in total, but sometimes I may only use one of the roving panels. And when under way normally only the 45 W panel.
When more than on panel are in use, they are connected in parallel into a Victron Smartsolar 75/15, which is also new. The 12 V house bank being charged consists of 3 x 90 Ah AGM batteries.
My basic question is are the two panel types involved compatible to run into the same controller? If not, what would be the best solution to maximize the yield? Connecting in series seems unpractical with my usage pattern.
I am well aware that similar questions have been asked before, but I have not found answers relating exactly to my type of setup.
