Solar Panel , how do I know it's working?
Applescruffs
11 Dec 2010
Here there and everywhere
Hello there.....
I've inherited a solar panel, I think it's from Maplin but as there is no led I have no way of telling if it actually works.
I've got a multimeter but it's been a long time since I've used one to measure voltage and current, I've only ever used it to check continuity.
Any hints or tips most welcome,
Cheers
rob2
23 Aug 2005
Hampshire UK
You should be able to simply measure open circuit voltage from the panel and this will well exceed the battery voltage.
Rob.
Kelpie
15 May 2005
Afloat
You will need:
- a multimeter set to DC in a range of somewhere around/above 20v
- access to the bare wires of the panel
- a sunny day
Check that the panel can produce around 16v or more (I think this varies depending on the make/model/size). Avoid any shadows at all on the panel.
Applescruffs
11 Dec 2010
Hi and thanks for the replies, I set the multimeter to 200 v and tested across the wires....looked like 24 volts !
That seems quite a lot for a 12 volt battery....or is that good ?...t not even that sunny here !
I guess I can assume it's working then ?
Not going to try the ' tongue test, madhatter.....even I'm not that daft ! :0)
Cheers.
ghostlymoron
9 Apr 2005
Shropshire
24v is on the high side. I've just fitted a 20w panel on 'Cobblers' together with a 5 quid charger I think it's open circuit voltage is around 18v. My charger has a green led to show when it's charging and three red leds to show the state of charge of the battery. If your registering above 14v, it's working.
C08
8 Feb 2013
Don't do what my mate did yesterday when the sun stuck it's head out - he tongue tested it , what a plonker squealed like a stuck pig ,I couldn't stop laughing
My father who was an electrician had a mate who always tested light sockets for being live by sticking his thumb into the socket when he would get a tingle through the thick skin...until one day he stuck his thumb into a socket and dislodged one of the prongs which shorted out the mains and the heat essentially cooked his thumb.
Interestingly people vary tremendously in their susceptability to electric shock. I suppose it is to do with the natural dampness of individual's skin and skin thickness. As a lad I worked at the Mines Research Establishment where we used whole arrays of post office relays for scanning temperatures in coal dust explosions. These were 50V DC and all the people I worked with never bothered to switch them off and appeared only to feel a slight tingle. I would be literally knocked out, feel pale and shakey and would feel the effects for days. I can also feel 12v as a distinct tingle!
johnalison
14 Feb 2007
Essex
I'm pretty sure my 36w panel gave something in the mid 20s when I checked it while fitting and I think this is quite normal. What matters is whether you need a regulator and this depends on the relation between the size of your panel and the battery bank, which I am not qualified to advise on.
VicS
13 Jul 2002
Hello there.....
Cheers
You may find the early sections, including the one on the "Use of meters" in the boat electrical notes from Tom Brooks' TB-Training website useful
http://www.tb-training.co.uk/cover.html
As suggested measure the volts out from the panel in bright light when it is disconnected from the battery. Expect readings up into the low 20s in full sun.
Measure the battery volts with no load on. Expect a reading up to around 12.7 ish depending on the state of charge. A little more if it's recently been on charge .
Connect the solar panel and you should see the volts slowly rise, perhaps to 18volts or more without a regulator if the panel is performing.
When you understand measuring amps try that after discharging the battery a little. The current you see will depend up the size of the solar panel and by how much you discharge the battery.
You may be able to estimate the size , in terms of watts output, by comparing the dimensions with similar panels on the maplin website.
A common rule of thumb for needing or not needing a regulator is if the ratio of panel power to battery capacity is no more than 1 watt per 10Ah you do not need a regulator although one is usually recommended for panels in excess of 10 watts.
William_H
28 Jul 2003
West Australia
You need to be able to use your multimeter on amps range. Often up to 10 amps. This on cheap meters usually means moving the +ve plug in the meter to "10 amps" hole.
You cna then use this to measure current in to a 12v battery. Without a regulator you should measure about .5 amp for a 10w panel. (roughly30cms by 30cms.)
You can if you wish simply connect the amp meter across the wires of the panel alone. This will short circuit the panel but should show again about .5 amp for 10w panel.
(don't forget to return the plug and the switch to volts after this test)
This shorting the output would be a terrible thing to do to a battery but is OK for solar panel. The solar panel has an internal resistance so that power is wasted in the panel itself. it gets hotter but not damaging or to a noticeable degree. This also explains why it is OK to connect a panel generating 20 volts to a 12v battery. The current draw max for the panel will reduce the panel voltage to that of the battery. On the negative side the high voltage no load will mean that it can continue to pump current into the battery regardless of battery charge state.
So it can overcharge the battery to the limit of the panel capability. ie .5 amp for 10w. So this current will not damage a big battery but can damage a small battery or a big panel can damage a bigger battery. Often suggested 1% of amp hour rating of the battery in solar panel amps or in any case 10watts is max to eb used for battery charging without a regulator. The regulator in various ways will stop overcharging the battery. good lcuk olewill
Seajet
23 Sep 2010
West Sussex / Hants
Applescruffs,
is there a diode and/or regulator with the panel ?
The diode prevents it discharging your battery at night, and the regulator from overcharging; my regulator on a 30 W panel has red and green LED's, green for good, charging - red for not so good !
A battery monitor installed on the boat is very helpful too, especially if relying on electrics such as depthsounder, gps, compass light etc.
Applescruffs
11 Dec 2010
Bloody Brilliant Link !
Many thanks for that VicS....and all the other replies....that's probably enough for me to be getting on with for the time being .....I can't wait to try it out now.
Cheers,
