RUSSH
I have done my inadequate best to search the forum, web and technical query to supplier to get the answer but to no avail so far. So over to you.
I recently purchased a Rutland 914 wind generator and an HRDI charge controller. I intend to also fit a single 100W solar panel via the charge controller. I see that the instructions for the charge controller states.
"Always fit an appropriate blocking diode to each solar panel input."
I have attached pictures of the solar panel connection box and the panel label. Looking at the connection box there appears to be a diode of some kind fitted.
My query is. Is this liable to be a blocking diode or a bypass diode? How do I tell the difference? If it is not an appropriate blocking diode and I need to purchase one what size/type would I require?
