Solar Gantry Cost
I only have the one boat ?
Once you have the equipment you can all all kinds of useful kit.
These are the weld bends use if the I need a radius tighter than I can get with my tube bender.
Stainless Steel Buttweld Fittings – Euro Steel, South Africa
If I wish to weld 2 tubes at and angle I use a hole saw to get the contour of the tube joint correct. Once setup takes less time that using a grinder of die grinder and makes welding eaer.
we have all that here as well but as i said they are not cheap, ,i have access to a bender but only dyes for 3 " up !! still i hope not to be doing any more gantreys !! ( although , judging by what people seem to be prepaired to pay local welders , it may be a possible earner when i finally get " away " , but that means carrying gas bottle , machine , bender etc !! i would need a trailor !! ) :)
