Walusotu
I have just upgradied my solar array to include a 180w and 50 w panel. They are connected in parellel and both show an open circuit voltage of around 19v.
I have a Victron 75/15 for charging. The charger to battery is fused. The wire for panels to charger has a single pole switch.
The open circuit voltage at the wires leading to the charger are also close to 19v and so there is little voltage drop between panels and charger.
I am presently in India were the sun is shining!
When charging I see a solar voltage between 14 and 17v. The maximum input after 1 day of operation was approx 2 to 3 amps but frequently less. The battery showed between 12.8 and 13.2v depending on cycling of the fridge.
Is there something wrong here?? What can I check further?
