Ceirwan
Thanks for the detailed reply. Sounds as if it might be worth looking at for my Hunter 490 - the loads aren't terribly high, half the shrouds are tensioned wit lanyards already and Dyneema stays would be much easier to store over winter.
For that type of vessel I would imagine they're ideal, especially if as you say you already tension with lanyards. It will be an easy job for you to change.
If you read this post:
http://forums.sailinganarchy.com/index.php?showtopic=168133&p=5090255
This guy got around the problem of getting the exact length of shroud correct by using lashings from the eye on the Dyneema, directly onto the bottle screws. That way he can also tension the rig much tighter.
He sailed single handed from the Netherlands to the UK this way so I guess its working well.
