PuffTheMagicDragon
IMHO they're one of the best sailing inventions of recent years.[/COLOR]
In my opinion I would put them on the same level as the invention of the Constrictor Knot and the Alpine Butterfly.
Among other uses, one is to close the front side of my home made harness: I make one turn with one winter clothes, two turns with summer clothes; the whole harness weighs just a few grams, no metal at all.
I'm not sure I can understand how that works. It is essential to be able to release a harness instantly in an emergency, at least that is what I believe.
b. World Sailing does NOT require quick release tethers, because some people disagree (if you are single-handing mid-ocean, is QR better?). In fact, Whichard only makes the QR tethers for the US market. I've been testing a prototype Proline for the past year; very nice.
Hello PMD,
the tether has a snapshackle indeed, at its body end; the harness itself is similar to normal ones with metal buckles, except I made it to my measures (so no need to have metal parts to adjust the shoulder straps), and instead of the usual front metal buckle with the D-ring I use the soft shackle, where the body end of the tether is attached.
rgds
According to the ISAF Special Offshore Regulations:
"5.02.5 It is strongly recommended that:-
d) snaphooks should be of a type which will not self-release from a U-bolt (see OSR 5.02.1(a)) and which can be easily released under load (crew members are reminded that a personal knife may free them from a safety line in emergency);
ALL of the boats that I have inspected in over fifteen years involvement with the RolexMiddleSeaRace had quick-release snap-hooks ever since the double-lock type came on the market. A large percentage of the boats are household names on the international racing circuit, having professional skippers and crews. Perhaps they only have a vague idea about safety.
As regards sailing solo - which is what I usually do - would I enjoy following a boat that is rapidly disappearing beneath the waves?
Now I understand. Thank you for explaining.
Apart from being light, the main difference is the location of the tether attachment on the harness: while wearing a lifejacket with harness, I was tossed a few feet away and retained by the tether. The attachment point was so low, almost at nostril level, that I feared having broken my back in two. On mine I raised the attachment point locating it above the sternum, IIRC there is some rule suggesting so (possibly OSR?), but above all it seems very sensible.
rgds r
b. Your text is thus out of date:
5.02...
5.02.2 b) not exceed 2 m (6’-6”) including the length of the hooks
5.02.2 c) have self-closing hooks.
Hooks are defined in ISO 12401 as...
4.3.5 Hooks
All hooks provided shall be of a self-closing type, with an opening large enough to accept, and fully close on, a
cylinder of diameter ( 0,1)12,5 0 + mm. There shall be no tendency for the hooks to open by any action, as
tested in 5.4, other than deliberate release, except when a clear and permanent warning label as specified in
5.4 and 6 g) indicates that an attachment bracket is fitted to the craft.
If intermediate hooks are fitted in a safety line, the test specified in 5.4 shall be repeated using each possible
combination of points of attachment. Each repetition shall meet the requirements of this International Standard.
The hooks shall be tested in accordance with ISO 9227. When tested for a period of 160 h, the hooks shall not
be significantly affected by corrosion.
[the test in 5.4 is for unclipping from a U-bolt]
I understand the reason for QR clips. I use them. If you find a current requirement, however, please share it.
So what has been effectively changed?
"All hooks provided shall be of a self-closing type"
By definition a 'snaphook' - the term that I used in my original post - is "Self-closing"
"There shall be no tendency for the hooks to open by any action, as tested in 5.4, other than deliberate release..."
A "deliberate release" can only mean being able to reverse the 'self-closing' feature quickly and using only one hand. That rules out unscrewing a long nut - which is ruled out because it would not be a 'snaphook' - and rules out the type where a sprung 'barrel' needs to be slid down to release the tongue - because it would not be 'self-closing'.
I have no wish to argue with you but I do look forward to seeing what type of hooks the crews will have at the end of their tethers next 15-19 October (during scrutineering). The start is on the 20th.
Probably something like the Kong "Tango", IIRC something very similar has been added to the latest Spinlock tethers just after the Clipper accident and following Maib report.
One (further) nice feature they have is the curved end hasn't got the small cut most other hooks have (to take the pin of the opening small bar), so when taking/releasing the webbing it does not risk to hook it.
Oh just found a picturethe end of the body, to the right, has no cut.
http://theopsdeck.com/img.prod.CTC/PROD - Kong Tango Safety Snap.open.jpg
They can be opened with one hand, however it's maybe the shape of my hand but I'd say slightly less friendly than say the wichards.
I like this idea. More than once I've experienced the same issue. Just pop them onto the jackstay tapes when the tethers come out.... I use soft shackles anywhere I think I might need to release the shackle whilst under way - there being no pin to lose nor possibility of the pin jamming. Plus a million and one non-shackle uses as suggested previously.We were on a boat where the jackstay tapes were very wide, causing the safety harness tethers to jamb going forward and back. Meant using two hands to move tether, not holding on, which kind of defeated the purpose. Used dyneema shackles to make small strong loops to hook onto, solving the issue, without weakening the tether or damaging the teak decks. NB. As not under constant load added sewing/whipping to ensure didn’t come loose when not under load.
