dougg
Where are you buying descent size quantities of Sodium metabisulphate from>
you can use either sulphite or sulphate the water maker wont mind they will both do the same job. I buy mine on ebay
http://www.ebay.co.uk/itm/1kg-Sodiu...Equipment_Lab_Supplies_ET&hash=item4aad2b9a72
the same suppliers can aslo provide citric acid and sodium hydroxide - (drain cleaner) the two cleaning solutions used for membranes.
how much you need depends on the volume of the system, the idea is to use the sodium metabisulphate at the end of the season to pickle the membrane, or if the membrane will be unused for over a week or so. The pickle solution acts as a barrier to prevent bacterial growth, its the sulphur that does the work, it denies anything living access to oxygen so it dies. If the water maker is in constant use - which is what they like - then you wont need much pickling solution.
Vic sodium metabisuphate not sodium sulphate!
the difference between sodium metabisulphite and sodium metabisulphate is not worth considering if all you are using for is to prevent bactierial growth in RO membranes either will work, sorry if I did nt make that clear.
Can it be used in water tanks for cleansing?
Oh and what on earth is sodium metabisulphate
Sodium metabisulphite is Na2S2O5
what is the formula of sodium metabisulpate?
technically the sulphate version has one more oxygen atom than sulphite which in turn should have one more oxygen atom than a sulphide, but all the suppliers seem to give the same formula whether its sulphide, sulphite or sulphate so I too am a little confused, but the good news is its not a show stopper - they all work.
