vas
season officially over for me today as well, so I can post on the thread
not bad for three + full weeks onboard!
V.
PS. run out of gas (3.5LT bottle) TWICE, have to make sure I have a full spare onboard all the time
- AIRMAR passerelle sliding extension has an odd ram extension of around 300mm which is flush to the main ram through an M8 thread that broke and let the passerele in out inoperational. Happened when I was abroad and wife with daughter went to clean the boat and managed to jam the passerele all the way out and down and bang it against the dock, not very easy to do, but wife is very good at doing impossible (as well as impropable) things (and obviously blames it on me afterwards...). Initially freaked out thought I had to take the bleeding ram apart, ended up a 1h dismantle, 10min machinist to remove the broken M8 and 1h reassemby, 5euro
- main heads not very good at munching solids
talking about jabsco el. toilet. suffered with it for three weeks, would occasionally block and once things dissolved, would flush just fine. Guess something broken/wrapped on macerator blades (?), will take apart at some point (not in a hurry) - a/p motor screws holding the manifold on the el.motor worked out loose dumping a litre of ATF in the lazarette bilge. Screws tightened, ATF refill and half an hour happily playing around with the two wheels to bleed the system off air.
V.
