BarryH
Checking over the lump I found snotty mayo lunps in the oil. With a curse and an eff here and there I dug the compression tester out of the tool box. All readings for all cylinders are within 5% of each other so the head gasket isn't the culprit.
Just to make sure I pressureized the cooling system 20 about 30 lbs and that held for a good couple of hours. So thats not leaking.
Run the thing up with indicator in the cooling. It didn't turn red so no combustion gases getting into the cooling at all.
Whipped off the oil cooler to check the seals in that. They seem ok and not leaking.
So a bit flumoxed as to what caused it. I drained the oil, filled with flushing oil and refilled with normal 15 40 semi and changed the filter. See how it goes.
Anyone got any ideas?
