BartW
Looking at the pictures it looks like unburnt fuel how many hours on the engines are they running at 3000rpm or 1500rpm do the genny's run for long periods on low load setting you say 4amps at 230v = 1Kw do they just charge battery's?
yes valve play is set at 0.2mm for all valves,
and indeed, its thrue that these genny's have been running most of their lives at 1500rpm and LO LOAD
my 2 curent chargers, are set at 200Amps bulk charging, but in our experience the period of bulk charging is not very long,
don't know real timings, but after genny start, we see on the display that the Victron invertor / chargers switch to absorbtion quite soon....(within 30 minutes or so)
moreover,
the charger on the engine bank only has to recharge the consumbtion from one Stabilising fin, (= not much)
we only use the genny's at anchor, triggered when we need the oven or the dishwasher,
or when the domestic batts SOC < 60%
(cooking is on Gas, and we hardly ever use airco at anker)
we have 2 x 610Ah 24V banks, one for Domestic and one for engines, and each bank drives one electric stab fin. via a 8KwVictron charger / invertor
so peak consumption on the genny is say 2 x 24 x 200 = 10Kw, but for less then 30 minutes,
its mostly much less then 5Kw...
the genny max power is 17Kw
