KompetentKrew
Hello,
My oven, a 25-year-old Smev 300 series, has a peculiarity that it doesn't like to stay lit unless fed WD40 on a regular basis.
Like all modern gas stoves, the knob must be held down so that the flame can be lit, and then for a few further seconds until it is hot.
All the burners on the hob work fine, although it seems like one or two need holding down longer than others.
The oven will work fine for a few days at a time, and then one day the flame will go out as soon as the button is released. It doesn't matter how long it is held down, or seemingly how hot the oven's burner has got - as soon as the button is released the flame goes out. I've tried holding it for 30 or 60 seconds, I reckon, and when lubricated it works within 5.
I was instructed by the PO to remove the knob when this happens and to spray a little WD40 underneath - in the mechanics of the knob, as it were - and then press it up and down a few times. The oven holds immediately the next time it is lit.
I think I've read here that WD40 isn't a lubricant but, whatever it is, it is the only way to mollify this mood. My oven deems 3-in-1 oil and PlusGas unacceptable offerings.
I would like to make a permanent fix. Is it as easy as replacing the thermocouple? From previous threads this seems like quite a straightforward job.
As always, thanks in advance.
