Small outboard with electric start
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
What's the lightest 4stroke outboard with an electric start???
Suzuki make a DF9.9A with and electric start option, but it weighs 40Kg!
My current DF2.5 weighs in at 13kg, which I can manage to lift off the dinghy onto the boat. I could probably lift a little more with practice, it's not the weight so much as the angle that outboard hangs at when lifted. I also want to avoid yet more clutter on the stern, in the form of a outboard crane.
The DF2.5 is OK as far as power is concerned, but some members of the crew can't start it and it can kick back like a mule.
It seems to me that there is a market opportunity for a small lightweight outboard with and electric start.
pvb
UK East Coast
I don't think you'll find an electric start outboard much below 40kg.
There are better solutions to pull-starting. My Stihl chainsaw has something called ErgoStart - you just pull the starter cord out, this winds up a spring, when the spring is fully wound, it releases and starts the engine. Pulling the cord is smooth, not speed dependent, and with no kickback. There's no reason why this technology couldn't be incorporated into small outboards.
penfold
25 Aug 2003
On the Clyde
That technology is as old as the hills; windy up spring starters have been around for decades, usually attached to emergency generators, firepumps etc. I imagine the tricky bit would be making it water resistant.
pvb
UK East Coast
Yes, wind-up spring starters are well established, but they require winding and then manually tripping. The Stihl ErgoStart does the whole thing automatically.
VicS
13 Jul 2002
Tohatsu offer electric starting on the 8hp and upwards. The 8HP weighs 37 kg
PaulJS
29 May 2007
Kirkcudbrightshire or off Saudi
As you can surmise from the "Which Outboard" thread I started yesterday, I've done a bit of internet research recently about small outboards, and I'm sure that I read that one of the modern outboards, Suzuki I think, has this, or a very similar method on their small engines.
Paul
pvb
UK East Coast
You're right! It's Selva, who have an "Easy Pull" system on their 2.5hp Seahorse motor.
Lakesailor
15 Feb 2005
Near Here
Perhaps some operator training is required. Many people pull savagely at the pull cord without having felt the point of compression first. Pull it gently over compression then let the cord back in. Now pull it to start, giving plenty of time to create rotation before a compression. Pull long and steady, rather than viciously.
If the motor is lower than the straight pull use the other hand on the cord to maintain the pull angle. (sort of a double-handed swing).
If it's kicking back are you using enough choke?
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
Thanks to everyone for their input, it confirms my own searches, and that no one sells a small lightweight outboard with an electric start.
I take the point about crew training, I don't have a problem starting the Suzuki DF2.5, except when I dunked it!
However, certain female members of the crew are "mechanically challenged" to the point where they find it hard to put diesel in the car .... so the very thought of pulling out a coke and using a recoil start, and then putting the coke in, isn't something they want to know about.
This means I'm usually the ferryman, my hope was that someone would have recognised the commercial opportunity.
penfold
25 Aug 2003
On the Clyde
Tell them to learn how to row?
