blampied
I'm toying with the idea of fitting a small diesel wing engine to my single engine (370hp Volvo) Aquastar motor boat.
We are living on the boat travelling around the western end of the Med (currently in Spain) but also includes slow canal and river use as we duck in and out of the French canal system. I am aware that using the main 370hp for long periods at or just above tick over (despite quick blasts when no ones about) is not ideal.
The Aquastar is semi displacement between 7.5 and 9 tons
Objectives:-
A get us home option if the main engine fails whilst at sea.
To be fitted with a large alternator for battery charging & to run through the inverter doing away with the genny
Allow us to travel at slow speed on the canals without constantly running the 370hp Volvo.
There looks to be easy installation access room in the lazerette
Looking for opinions on are my expectations realistic:-
What are the ball park costs likely to be for the motor and installation
What size hp motor should I be looking for? (I'm guessing about 30hp?)
Assume it will need to be a folding prop, would 2 blade do or would 3 blade be better, (smaller diameter closer to hull?)
As main motor is TAMD Volvo.
should I stick with looking for Volvo (D1-30 or similar)
i understand other makes can be cheaper? Cost would be a big decider.
As I'm in Spain (thinking about Cartagna for winter) I'm in no position don't have anything more than basic hand tools on board to do fitting an engine, so would need to be a boat yard job.
Any recomendations of a reputable boatyard in the area.
Thank you for looking.
Objectives:-
