rogerthebodger
What ever you store your safety gear in it needs to be water proof and tied to the boat so you don't loose it if and when the boat capsize
Its all kept in a large dry bag clipped behind the helm for easy access but away from main deck. Saves having to dig it out of bow storage in a blind panic in an emergency.What ever you store your safety gear in it needs to be water proof and tied to the boat so you don't loose it if and when the boat capsize
Good point i may have to rethink...That's fine but can you get to it when the boat is inverted.
Mine has a line that is 1 1/2 the length of the beam of the boat so it can be accessed and pulled from under the boat without the risk of it floating away.
Thank you ?Dan 208,
I like the way you're thinking, consider lots of possibilities, take account of what you can and take what practical measures there are but at the end of the day even if your plans may be adjusted, don't let all the different opinions put you off.
The exercise of thinking round the problem is v valuable.
Would the fold down tube ones be any good?Not seen anyone mention a radar reflector yet, Echomax do a smallish and light but effective one which can sit on your cuddy roof. You may not intend to go out in fog but at some point you’ll probably end up in some.
They’re not generally well regarded although I do pick up small boats fitted with them on my radar. If you go that way get one of the thicker ones, Echomax really the way to go though.Would the fold down tube ones be any good?
I was thinking about that last july but my soggy deck took centre stage and i totally forgot about it lol
Il take a look online...do they need to be wired up to my nav in any way? Is is similar to AIS?They’re not generally well regarded although I do pick up small boats fitted with them on my radar. If you go that way get one of the thicker ones, Echomax really the way to go though.
No wiring or power required, they just increase the likelihood of creating a radar return. Fit and forget.Il take a look online...do they need to be wired up to my nav in any way? Is is similar to AIS?
I did fit 2 small inspection hatches
