Pye_End
How much of the rest of the system is below water - if it is leaking only when the engine is not running, and when the seacock is open, then would have thought it must be on the inlet side, and on something which is below sea level. Perhaps from the front of the water pump?
Does it happen when you are sitting in harbour or just whilst you are underway?
Could there be something odd going on with the shaft seal - what sort of seal do you have? A grease seal will leak when turning, but a lip seal type could leak only when under power.
