Babylon
When re-rigging at the start of last season, the riggers pointed out to me that our 30ft single-spreader Kemp/Selden mast has a slight S-bend in it, just below the spreaders. They predicted that I'd probably notice a slight difference in speed on one tack or another.
(The probable cause of the S-bend goes back to the end of the previous season when, beating into a F6, my crew set up the running-backstays but I didn't at first notice that the lead wasn't correct, and we sailed, short tacking, for ten minutes or so with the running backstays twisted around the lower aft shrouds before correcting this!)
During the season I did in fact notice that we seemed to sail slightly faster on Stbd tack than on Port, but only very marginally - until the last sail of the season when, for some reason, beating into a F3 against a foul tide in sheltered but open water the log-reading for speed showed 3.5 kts on Port but 4.25 kts on Stbd, a difference of 0.75 kt!
Could all this be due to the S-bend (which is stable and hasn't got any worse over the season), or could some of this have been due to other factors (ie particular conditions, log-impeller offset just to Stbd of long-keel, weed fouling the impeller more on one tack than the other, etc)?
And what can I do about the mast itself? Its structural integrity isn't compromised (in fact its a pretty bullet-proof cruising rig) and new one would be extremely expensive. Is there any way, with the mast unstepped, that the S-bend could be worked out - or would this fatigue the aluminium?
