Beautiful! Looks like you are somewhere in the Mediterranean! But in which country?
sa FranceBeautiful! Looks like you are somewhere in the Mediterranean! But in which country?
On the fabulous Côté dAzurBeautiful! Looks like you are somewhere in the Mediterranean! But in which country?
To drift the thread a bit more, those who use a snubber bridle, do you just thread it through the chain and then back to the boat? One end going through the port fairlead, one end going through the starboard one? Or do you hook/tie the middle of the bridle on?
What is one going to tie the bridle to that is further aft than the transom?I assume you commence your bridle at the bow cleats. If you commenced your bridle at the transom, or further aft, you would enjoy much more elasticity.
Jonathan
Richard
Ok, this is me right now! I’m at anchor in shallow water. There is my stubber, it’s a chain hook on a bridle with dog bones. And you can see my 20 kg Rocna. I hope to sleep well tonight, if I don’t, no problem, because we are the only ones here in this beautiful bay on this beautiful evening and it is a full moon. Should you really sleep through it ??????
I would have thaought that you of all people would have heard of a bumkin.What is one going to tie the bridle to that is further aft than the transom?
Richard
It was power set but not a great deal of power. I also think that a lot of sand here is over rock. But, except on the internet I have never seen the Rocna bury very deep. But it does hold, that furrow in front of the anchor is from the setting. It then stopped the boat reversing.I'm sure it is calm, but that anchor photo does not calm me at all. The anchor drags in from the bottom left, indicating it has been scraping but not going deeper. The suggestion is that the sand may be over hard pan (flat rock) and the holding power is probably not more than the sand in front of the anchor, maybe a few hundred pounds. Heck, the back of the fluke is not even flush with the sand. Was it power set? Was the boat motionless for a time period or still creeping backwards?
Not confidence inspiring. Alarm bells if any wind is expected. But maybe there will be no wind.
And yes, there is no wind? in fact we have spent most of the time with the anchor beside the boat
If you search on the word as spelled, you should get a result that is meaningful in context ?From OED:
bumpkin
noun
- a person from the countryside who seems stupid.
I couldnt agree more. We dont fret at anchor and dont set an alarm. Hundreds of nights at anchor in a typical season and plenty of good sleep. We are similar in that we never go in to a marina except at the end of the season when we lift out. Typical normal non-covid season is 9 month all at anchor?Anchoring and sailing have always been synonymous for me. In fact, until I had my own first boat, which I kept in a marina, I had never slept on a boat that was not at anchor and even then, whenever I went cruising, I only once stayed in a marina and that was for the sole convenience of picking up friends. I simply did not know it any differently. We did not fret about anchors either; my Dad's boats all had Danforths of indeterminate sizes with a chain leader and line, the ones that are regularly rubbished in the new-gen anchor tests. It was what I used (at first) as well. We dragged, occasionally. It happens, nothing dramatic, reset and have another go. Anchor alarms? "Yah, sure, keep an eye on that tree, boy, and let me know if it moves."
When I sailed from Europe to the Canada's West Coast, the times I tied up in a marina in the Med I can count on a single hand and after the Canaries, other than for bunkering fuel and water, the boat never touched dry land until we reached San Diego. We dragged only once the entire voyage. It was in the Med. Right at the outset and first time we dropped the hook, in Calvi and it was blowing some 40kts. Fortunately it was during the day time, but it did smarten up my technique something wonderful.
Cruising Europe in our current boat, we still anchor a lot. When conditions warrant, I get up at night to check the plumbing and to see if that red marker is still where it was last, but other than that we do not give it all that much thought. We still use no anchor alarm. In the Dutch Waddenzee we rode out a F8 over night, on the old CQR that came with the boat; we slept, mostly; I did occasional checks, as there was a lot of current as well and I was concerned we might shift over a drying bank. According to what you read these days we should have woken up in America, but the way my missus set that hook I'm sure it must have shifted the continental shelf.
My take: you do not have to start your anchoring career in 40kt winds, pick some mild weather, a good bottom, set that hook proper and enjoy. Nothing short of sailing itself can give you that sense of independence, even if they seem to like to charge you for the privilege of wetting your own hook on the South Coast.
Just for your sense of comfort: calculate the actual wind loads and if you like, the expected tidal force for your boat. Compare that with the break out loads for your favourite anchor from the numerous tests that have been done. I did, quite recently, and found that even in a 50 kt breeze I would still have a 50% safety margin.
And with that I wish you a good night and a sound sleep.
