will be better to put the handle in the other socket & turn anti clockwise to unscrew the top plate :encouragement:Put a winch handle in the centre and unwind it anticlockwise. The gypsy will then come off, but will probably need a bit of persuading.
Thank you for your replies. The off-set socket doesn't appear, from the windlass itself or from the exploded diagram, to engage with anything within the windlass. Is it solely intended to provide leverage for the winch handle? The gypsy pawl is currently seized in the open position. It will respond to a sharp knock with a hammer but I'm reluctant to use brute force in case it results in damage.
