pperrin
New Member
I am pretty new to this, but have a sail that needs some work (reefing points)... I am pretty handy and am used to hand sewing heavy material (leather)... What I don't have is large heavy duty punch/setting equipment.
So rather than putting metal grommets/eyes in to the sail, I am looking at just adding webbing straps/loops (with reinforcement panels), then having metal shackles/horns etc directly through the webbing loops. This way I don't need any new equipment, just a bit of sailcloth, webbing, thread and hefty needles.
So reefing pennants would be a strap sewn to either side of the sail, no hole through needed. The reefing clew and tack just a loop of webbing (without without a metal ring using a cow hitch or piwitch knot, which could be put on/removed as required, so not flapping around when not in use). I woudn't fancy running rope through a webbing loop, so would use rings if it wasn't going over a metal horn or similar).
Good idea? Bad Idea? Old hat(!)?.
