Skin fitting hydrodynamics
scrambledegg
2 Nov 2015
Portsmouth
My boat is in a yard about to have all its skin fittings and seacocks replaced. It currently has flush fittings and I could replace like with like, but it is cheaper to replace with the slightly protruding type with external flange. There's going to be increased drag with these protruding types and I am reluctant to go that route but the economics can't be ignored.
Does anyone have hard data about that drag increase?
My limited understanding is that such a skin fitting on a part of the hull that has laminar flow could increase drag considerably , as it would cause the flow to transition from laminar to turbulent. On a part of the hull that is normally turbulent perhaps it would have very little effect on the drag? Unless, that is, it provokes flow separation. Where on typical hulls is the flow laminar and turbulent?
As you can tell I am guessing quite a bit. Is there anybody out there who's studied this, or knows of a study and would be prepared to share?
Yours hopefully.
europe172
2 Sep 2007
As far as i know the flow will be turblant after about 18 inches at 6 knots, so most skin fittings are after transition. That said flush or no fittings are better than proud fittings, how much better is difficult to calculate depending on where on the hull they are located.
Woodlouse
7 Jan 2006
Behind your curtains.
The hole in the skin fitting is going to cause turbulence too whether it's flush or not. I'm of the opinion that unless every 100th of a knot counts then it probably makes very little difference. Do you longboard the bottom after you antifoul?
scrambledegg
2 Nov 2015
Portsmouth
Thanks guys for the responses. I had to google "long-boarding", so I have at least learnt something.
It seems that hard evidence may be lacking, but that the drag increase may be relatively small. With 8 of them in my boat, I wonder if it adds up to something significant.
SailSouth
9 May 2017
Central Solent
Www.solentboatbutler.co.uk
You could fit the type with an external flange and then fair that in with some underwater filler to reduce the drag of the flange. Arguably that adds weight but it a compromise that may work. Pretty sure I have seen this done on a few production/racing boats.
mrming
28 Jul 2012
immaculateyachts on Instagram
instagram.com
Yep it's pretty common to fair them in. I thought about it but didn't bother (there are 3 on mine). A bad tack or two would cost you more imo.
CCJ
24 Jul 2017
I have Elanco seacocks Landermores supplied & fitted them
lpdsn
3 Apr 2009
Fantastic!
If I can find a local measured mile and a way to reproduce exact engine revs, it would even be do-able.
Having a fair hull (as achieved by long-boarding) is generally considered to have the most impact at slower speeds. Within that the for'd part of the hull is considered the most important (apart from the foils) if you have to cut corners.
So a lot of it depends upon your attitude to low-speed racing. I find it the most challenging but you do have to pay an awful lot of attention to detail. If you're doing that throughout then you'll want faired skin fittings. If you let your crew clump about like yetis on a beach holiday when the wind gets light then it's not worth the bother.
