STOL71
Buy yourself a long keel boat with a transom hung rudder. The rest is just thinking ahead and talking to as many sailors as possible.
Never hurry
Never go anywhere without the main ready to go.
When it all goes wrong either make sure no one sees you or pretend you meant it to happen that way.
Use all your fenders.
Don't forget you've put the kettle on.
Untie the tiller/wheel before you cast off.
Have a pee before you cast off!
If you're coming in somewhere at night keep a transit behind you. When it all gets a bit scary do a U turn and motor slowly back out the way you came in. That way is definitely safe and chances are you'll start to work out your surroundings ready for a second try.
Apart from all the obviously useful and stated ideas don't forget to have a pee receptacle to hand for that time when you are just about to enter a harbour and you suddenly remember you are bursting for a jimmy. I have a black plastic bicycle drinks bottle nearby with a large letter P stuck on it. Just a thought.
Only thing to add here is that I have a long keel so I plan manoeuvres well x3: A, B & C.That is brilliant. I would just add that I find doing anything at sea quite easy as there is time, but well worth taking lots of time learning to make your boat spin on a sixpence under motor using whatever combination of techniques works for you. That makes parking (the difficult bit) so very much easier.
Get a good autopilot as a priority.
Why you need an autopilot if going further than a little pootle about in the Solent -
https://www.youtube.com/watch?v=JT9olDqkRpA
"My trip was a nightmare, one of the worst I've ever done , because I lost the autopilot"
And lets not forget......
In this context, It's difficult to see many advantages in modern style bulky boats but there is one trick they have which is invaluable for singlehanding; the ability to steer in reverse.
With the breeze against your bow, reversing out of a pontoon slot, the burning question is: "can I get it through the wind?" With a thin keel you know, even if the bow blows right off, it is an easy matter to reverse up the exit. The long keeler can get tangled in the arcs of despair, inevitably ending pinned across the bows and sterns of downwind pontoons.
Now't you can do.
Yes there is. Warp her out. Done it a few times when the wind looked iffy. Mind you, a kink in the warp stopping it from running free can also spoil your day.
