single line reefing setup help
30 May 2013
Hi,
we have slab reefing and the clew is led back to the cockpit, the Tack has to be done at the mast, i.e a reefing cringle ring shoved onto a the rams horn (at least thats what i believe their called!)
we're looking to change to single line reefing at least for reef one and two, looking at the boom there is space for rollers at the mast end although not fitted (see photo)
What im thinking of doing is adding a block onto the reef cringles at the tack and take the line up the outside of the mast around the block then through a new roller i need to fit into the boom (on the top bit) then over to the existing clew reefing point where you can see the rope looping out
few questions,
will this work
what are those rollers called in the boom
can i retrofit said rollers into the boom end
i assume i cant use the existing bottom rollers in this set up
any help appreciated
William_H
28 Jul 2003
West Australia
I would advocate leaving the clew reefing as is and adding another line for the tack. In my experience this can give a good flat reef. The down side is that to set up all 3 reefs you need more lines.
Take the tack line from a saddle on the mast below and well forward of the gooseneck. Run it up to the eyelet and back to a cheek block or another saddle again well forward and below the gooseneck. From there the line goes down to the deck then back to a winch cleat etc.
The location of the saddle and sheave will give a pull that is at 45 degrees to the luff and foot so pulling the tack right into the mast (taking load off the luff slugs or bolt rope) and close to the boom making a tidier reef.
I would suggest give it a go with first reef and see if you like it for not much cost or changes to the mast. ol'will
Daydream believer
6 Oct 2012
Southminster, essex
I think that you will find that Barton do single pullies. For a spindle you could use a long drop nosed pin
you will need an aligner on the mast to keep the reef line that drops down to the deck well forward ( the green one in your picture) not sure what it is called. A cheap option is a stainless steel ring held in a reefing eye pop rivited to the mast. This does tend to wear on the rope though. But ok for trials
Charlie Boy
14 Jul 2019
Alongside Ukraine
We have two lines back to the cockpit. With three reefs available I have always been fine about going up to the mast for the first reef but IF I need the third I’m not going anywhere near it!
So, the tack line for the third reef is permanently attached to the appropriate crinkle and runs back to the cockpit through a cleat. The clew line goes through the boom in the usual way then back to the cockpit through another cleat (obs)
tross
19 Aug 2003
Lymington
I have just added a thrid reef to my two reef single line system. I had a spare sheeve on the mast end of the boom but it pointed downwards ( a bit like yours). What i did, was to take the line downwards to a block at the mast base, then up to theClew reefing point( I have rings and ears sown into my sail and then down to the normal mast base block array for the reef and back to the cockpit.
30 May 2013
I think this may work and be the simplest way of doing it I found a sketch someone else had done for inspiration, although as I type I’m now wondering how to reef while still going upwind for example with only the boom angled to the wind ( which would be a Nightmare wouldn’t it?? Ie if the boom was far enough over it would rub on the rope going to the lower block or am I over thinking it??) and brings me back to looking for sheaves for the boom. (One step closer knowing their called sheaves / sheeves:)) 79247895-B54D-4900-954A-EB1A1F95BFE6.jpeg
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I think this may work and be the simplest way of doing it I found a sketch someone else had done for inspiration, although as I type I’m now wondering how to reef while still going upwind for example with only the boom angled to the wind ( which would be a Nightmare wouldn’t it?? Ie if the boom was far enough over it would rub on the rope going to the lower block or am I over thinking it??) and brings me back to looking for sheaves for the boom. (One step closer knowing their called sheaves / sheeves:)) View attachment 80104
After years of successful use of my balance block system (http://coxeng.co.uk/sails-and-rig/single-line-reefing-diy-system/) I suspect that with the one in your sketch it might be quite difficult to achieve adequate clew tension. I find with mine that raising the topping lift far higher than its final position helps to get the sail tight along the boom but the additional friction at the tack end of your diagram might require very heavy winching even with the topping lift high.
gregcope
21 Aug 2004
The “rollers” are boom sheaves. Your boom looks like a selden one.
You will need “forward upper sheaves, spindle, circlips and washers”. Part numbers depend on which boom you have.
A good rigger should be able to supply these. I got mine from Martin Leaning Masts & Rigging Ltd.
30 May 2013
how does one go about getting a balance block into the boom? and how do you stop it interfering with the reef 2 balance block?
30 May 2013
yes it is a seldon boom, although not sure of its part number, ill have a look around for a part number somewhere, were they expensive? as i could always fit some forward upper sheaves :))) and if it all gets into a winching nightmare i may just stick with what i have!
blackbeard
17 May 2003
Hampshire
I have a very simple system (3 reefs) similar to illustration, on a 25-foot boat, and it's fine. Be sure that every time the rope changes direction it does so via a sheave or pulley of some description (ball-bearing for preference) and not, for instance, directly through a cringle as is sometimes done. Use the lightest line (high-strength low-stretch for preference) which is adequate for the job. Friction is your enemy.
I suspect that on a larger boat, a more elaborate system might be needed, possibly one line each for the new tack and the new clew.
As suggested above, a little experimentation would be in order as the easiest way of finding what's right for your boat.
vyv_cox
coxeng.co.uk
Drill out the pop rivets holding the end cap. I used rivnuts to put it back rather than more pop rivets, which has been useful when my crew pulled all the pennants out.
Provided the lines are all as they should be down each side of the boom with the outhaul down the middle the blocks will not clash. It was in 1992 that I first developed this system and I have used it ever since. The blocks have never clashed once.
dgadee
13 Oct 2010
I have 3 single line reefs. An awful lot of line comes into the cockpit and there's an awful lot of friction (glad I have an electric winch). I am thinking of going to 2 line reefs.
Daverw
2 Nov 2016
Humber
We have 1st reef single in boom and second reef two line, works well, I did think about adding the second to in boom as Vyv has shown in the past, would reduce the reefing line length.
Old Bumbulum
11 May 2018
At risk of sounding a negative note my expereience with this seemingly good idea is the sad fact that it seldom works as expected.
The wonderful idea is all too easily overcome by the fricton in the multitude of blocks is all too likely to make the whole system utterly useless in any sort of wind. It is all very well for it to function smoothly in the marina in calm demonstration conditions, but put a real force 4/5 load on it and it simply isn't likely to function as advertised, and that is the last time you want to find that out.
Doubtless many will rubbish that opinion, but I suspect the majority of serious sailors who have tried it will concur...
I'm not saying it can't work, more that it it is unlikely to work reliably or well.
There are simpler solution that are guaranteed to wotk better.
So why not use them?
vyv_cox
coxeng.co.uk
Interested to hear I am not a serious sailor.
gregcope
21 Aug 2004
I brought two; for a larger boom; £40 odd I recall.
flaming
24 Mar 2004
I've used the system in the sketch extensively on a performance cruiser with laminate sails. There is no issue with getting adequate clew tension. It's simple and it works.
