Simpson Lawrence Windlass Help Please
Jurgen
17 May 2011
Bristol Boat in Mercury
Hi all, hope someone can help.
T
Was at anchor yesterday for a few hours, went to lift the anchor but all I got was a whining noise when up button pressed!
Pressed the down button and about 300mm of chain came out, then pressed the up switch and 300mm came up the stopped.
Battery is fine so guess the problem is in the windlass.
Any help / advice appreciated
kashurst
10 Oct 2003
Spain
probably duff connection either in the contactor box or stuck brushes in the motor or carp in the commutator on the motor armature - if the battery is OK.
sunquest
31 Oct 2005
Kent
I had a similar problem with my SL windlass when it decided enough was enough. Turned out to be seized bearing on the main drive shaft. - comes with age;)
Wavey
26 Jun 2011
Home - Surrey
SLS are very good and rebuilt my Simpson Lawrence when I was sure (having taken it apart) that it was a bin job. Excellent service, much cheaper than a replacement, and you won't find another with the same footprint anyway so a replacement will mean chopping the deck to make it fit.
Jurgen
17 May 2011
Sounds like the best option, will give them a call for a quote
