Danny Jo
Simplifying \"single-line\" reefing
Freestyle's main has three slab-reefing points. The main halyard and the reefing lines can be operated from the cockpit. The first two reefing points are rigged up for single line reefing. The third reef has a line through the reefing point on the leech, but you have to go on deck to hook the luff ring onto the thingummyhook at the gooseneck.
Leaving aside the absurdity of being able to take in first two reefs from the cockpit, but having to go on deck to get in the third, I don't like this setup because it is a helluva job to shake out reefs 1 and 2. There is just too much friction in the system for the main halyard to overcome (not helped by the fact that the fairlead guiding the main halyard into the mast forces the halyard to make a double-bend). I suspect that this makes me slightly more reluctant to reef in the first place - in other words slightly more likely to dismiss wind speeds of 20 knots and rising as "just a little squall - it'll pass in a minute or two".
Replace the 20-year-old blocks and installing smaller diameter lines might ameliorate the problem, but I doubt that it would cure it. I am inclined to replace the complex arrangement of cars and lines in the boom with simple lines that work on the leech points only. If there is a justification for a second line for the luff point, then surely that should operate on the third reef?
Has anyone attempted to simplify single-line in this way?
