AntarcticPilot
I was going to suggest measuring it in km, then converting it as I thought I remembered that it was a very simple conversion, i.e. 2:1. Before posting I looked it up in a reference book I use frequently and was surprised to see that a UK nautical mile = 1853.2 metres whereas an international nautical mile = 1852 metres. New one for me.
And if you use the latitude scale of a chart, the length of a nautical mile varies with latitude!
Originally, a nautical mile was defined as one minute of latitude; convenient for navigation, and if the Earth was perfectly spherical, the same everywhere. In a similar way, the length of the metre was originally defined as 1/10,000,000 of the distance from the equator to the Pole (it's close enough to be a useful approximation).
Unfortunately for those who like units of measurement to be fixed quantities, the Earth is not a perfect sphere, but approximates (pretty closely) an ellipsoid - in other words, it is a bit flattened, so the diameter between the Poles is less than the diameter measured across the equator. That means that the length of a degree of latitude is less at the equator than it is at the pole, so that a minute of latitude (i.e. a nautical mile) varies by 18.66 metres between the equator and the pole.
The difference between the Uk and International nautical mile is a matter of choices made historically; both are reasonable mid-range figure that will be "close enough" wherever you are.
It's only in these modern, GPS days that errors of measurement of a few metres have become relevant.
