Firefly625
12V ELECTRIC UNIVERSAL PETROL DIESEL FUEL PUMP FACET POSI FLOW STYLE CAR VAN | eBayWhat model pump are you using?
Q for Refueler et al, hope OP don't mind:
As others, I have been using M16 for years, before that, I rotated different treatments and water dispersal products. My annual fuel turnover is low, one major trip a years requiring several tank refills, lots of short 18-26nm coastal hops or trips around the lagoon. Fuel looked clear when last inspected.
So, onto my questions: 1) Do you think it is worthwhile polishing fuel in tanks once a year? I would probably start with 30mic and then change to 2mic filters - I would be interested in the results, monitoring pressure drop, clean against challenged filters for both filter sizes? 2) Do you think water dispersal is beneficial or simply continue with M16?
I have excellent accessible drains at the base of each tank that already have lever operated gate valves so really easy to do on my boat, tank sizes are each 818L capacity.
A cupful of water in such a small amount of fuel is very abmormal. I'd be worried about a major leak of water into the tank. Have you tried putting a dip tube in to measure how much water settles out, or by draining from the bottom?Sediment is from centrifuge bowl. Total water removed about a cupful.
This is from a long range tank that I gather from 2 previous owners has sat for at least 2 years and has been carried around in the lazerete holding the back of the boat down, as a rough guess about 10 jerrycans.A cupful of water in such a small amount of fuel is very abmormal. I'd be worried about a major leak of water into the tank. Have you tried putting a dip tube in to measure how much water settles out, or by draining from the bottom?
So that's a cup out of a 200lt tank. Not so bad. I misunderstood.This is from a long range tank that I gather from 2 previous owners has sat for at least 2 years and has been carried around in the lazerete holding the back of the boat down, as a rough guess about 10 jerrycans.
the outfeed is at the lowest point of the tank as there is no dip tube. It is from here it is pumped into the main tanks.
First polish revealed no sedimented water, just emulsified. Then dosed with de-emulsifier to give a cupful on first pump run a few days later.
Yep same as mine as well - as you would expect.The following is an interesting video from Separ, its the model of the primary fuel filter I have fitted on my boat, the cartridges go down to 10mic which I may use for polishing with 30mic in use:
Useful video from Separ
Doubt it.Can you find out the differential pressure that your switch operates, to tell when the filter is challenged?
Leave it to stand for a few weeks and see if it clears naturally. If it does pass it on to you nearest Corvette owner - he will get rid of it for you !Update.
Double dose of de-emulsifier, after 4 days fuel did not clear and no more water in the separator.
It was suggested that it may be petrol as this was sometimes added to stop fuel waxing if very cold, though modern additives have negated the need for this.
4 different people have sniffed and said without any prompting that it does have a faint smell of petrol.
So have now got 8 containers of cloudy diesel kicking around.
I am also told that I can feed this into main tanks at 10% rate.
However I am also also told that the petrol in the fuel will remove the wax coating on the 1st stage filters which is there to collect water and drain to the bottom of separator bowl.
Not so worried about the cost, it is just a pain to dispose of so much fuel
It has already stood for 3 yearsLeave it to stand for a few weeks and see if it clears naturally. If it does pass it on to you nearest Corvette owner - he will get rid of it for you !
