Yellow Ballad
I need to make a new dip tube for my diesel tank for my diesel heater. I have the fitting 3/8 brass elbow to fit the union on the tank, I've got a brass "plug" with a 5mm hole in the middle and some 5mm brass tube.
What's the best way to stick them together? I have regular plumbing solder here, I don't mind buying some silver solder if needs be but thought I would ask on here first. Obviously it's not something structural but I don't want any air leaks from the joint.
Over to you...
Over to you...
