dickh
I have a 2HP seagull outboard; it was one of the first with Electronic ignition. I stopped using it about 2 years ago as it wouldn't start easily or run properly so bought a Honda 2HP as a replacement. Having a clearout, so with the intention of selling it I started to check it over to get it going again. I fitted a new plug, clean fuel and cleaned out the carb. - and it started after 3/4 pulls. Great I thought, I'll check it again tomorrow evening and then advertise it, but next day it wouldn't start, or the next... After several attempts and further carb cleaning and checking etc still no result. I have a good spark so it appears to be fuel related? The carb is assembled correctly ie the screw holding the centre jet assembly is in the slot and not in the fuel hole, there is fuel in the float chamber and the filter is not blocked.There appears to be good compression so I don't want to strip it completely to inspect the innards
Can anyone give any further suggestions - I'm loath to just scrap it as it used to be very reliable.
