dickh
Thanks for all the suggestions, situation as follows - I cleaned out the carb, fuel tank etc, old plug set to .035"(approx - feeler gauges on boat...), fresh mixed petrol(checked plug lead but cannot replace as engine end is sealed) and lo & behold it started after 3-4 pulls! It was not running perfectly, idled OK but was hesitant on acceleration & high speed, seemed to prefer ½ choke. There was a small air leak at the crankcase split line, but I stopped and started it several times OK. I will check if it is still running tonight, and will strip down and lap the split line faces(or might just try Hermetite).
