Shower pump / water requirements
:encouragement:
But I use a sponge rather than a flannel.
The built in sink shower tap never gets used.
A further consideration if you spray water around the heads is waste water removal, if gravity will do the job, no problem, but if not you will need a pump out system, either another electric pump or a manual one.
I have heard of, but not used, boats where the shower water goes into the bilge, where the bilge-pump does the job. If using an electric pump you need a filter for crew members who moult.
My old HR352 had the shower draining straight into the deep bilge sump. I only had a manual bilge pump, so no problem. However, I don't think it's a great idea.
It's a bad idea, the soap and shower water creates a terrible smell, I sailed on someones boat that did that and it was appalling.
We can easily get four Navy showers from our 29litre calorifier and still have enough water for washing up. No thermostatic control on the calorifier but we do have a thermostatic valve on the shower. The first water to come through on the shower fills a kettle for the morning tea. We shower in the hot stuff.
We use the generator to run the immersion heater (1200w) when we need to. We get 2 hot showers from 15mins of generator run time. If you oversize the calorifier it takes more energy to get the water warm so you can shower. Friends have just removed a 50litres calorifier to install a smaller one for this reason. The problem is made worse if you mount the calorifier on its side. At least with a vertical calorifier you can take the advantage of stratification in the tank and just use the warm water at the top.
Same set up on our Voyager. Shower used the same drain channel as the anchor locker to run to the bilge sump where an auto pump threw it overboard together with anything else that had found its way down there. Not pleasant. Soon changed it to a proprietary shower sump/pump but found it unreliable so replaced it with a diy sump, gulper pump and simple electronic timer/delay circuit.
I'm glad ours are both self contained drains with their own 1.5l sumps. Both to avoid smells and hairs in the bilge (and even the mini sumps smell if left for a few days), but also because when the sump cover starts floating you know you've used the next 1.5l so time to hit the drain button for a few seconds. I find I use about 3l for a full shower with hair wash and a quick spraydown of the heads.
Ours used to drain straight into the bilges but I didn't like the idea because of potential smells and build up of hair and old soap so I've connected a hose from a whale gulper pump directly to the shower tray outlet. This works well.
Our shower sump is 7 litres with a 2000 gph bilge pump and float switch. It runs automatically and is also part of our emergency pumping system. The big pump is very tolerant of the mrs long hairs but does need a clean out periodically. It doesn seem to get smelly
