rogerthebodger
What's the difference between motor high and motor low ?
Ariam is under 12m so it’s legal to combine masthead and stern light into a single all-round white, used with the bow bicolour. That’s “Motor High” - not something I often use, but the lights already on board allow it so I added the option in case the normal stern or masthead light got damaged, or I thought a light at the top of the mast would be more visible in the conditions for whatever reason.
This is mine. 6mm plywood panel with a custom printed layout on top. LED lighted switches wth push reset breakers. This is fed by the house batteries via a standard 12v cut-off switch. I also have a garage consumer unit nearby for mains input that has 2 x mcb's. 1 feeds a mains charger and the other a single 240v socket. Unless the boats in the yard for maintenance this is only used for 1 thing and thats a small electrical 800w heater. Don't really see the point of mains on board a boat, more or less everything you need to live comfortably can be had in 12v. They certainly shouldn't be wired together into one switch panel. I think they have to be kept in seperate conduits for boat regs?
The horn circuit was never wired but is now the feed for the diesel heater which I installed few months ago.
Here’s mine:
I’m still quite pleased with the front of the panel, but I’d do a much neater job of the wiring if I were to start again today:
View attachment 92076 / View attachment 92077
I did labels with 6mm Brother Tz tape lengthways along the wire, then transparent heatshrink over the top.
All the fuses are here except for a handful where it wouldn’t have made sense to run a wire all the way across the boat and back (these items are all right next to the batteries, and two out of three need to consider volt-drop):
...but not everything is switched at this panel, because many things make more sense controlled from somewhere else. This is the main set of cockpit switches, for example:
And of course some things have switches built into them and don’t need a “master” switch at the chart table.
There’s some stuff I’d do better if there was ever a third boat, but broadly speaking I’m happy with this system.
Pete' is very nice and I did a nav light switch similar to Pete
Mine Is marked
Off
Sail (Bow bi colour + stern)
Power (Bow bi colour + stern + steaming)
Tri colour ( Mast head)
Anchor (All round white)
Anchor Auto ( All round white with day light sensor)
I used 6 way 2 pole wafer switch as the switch like this
This is the best pic I have
I also included a diagram of the boat with the various lights indicator LED's
The top one just by the top fan blade.
one of these behind the panel:
VHF and bilge pump are wired directly to a HOT bus whist everything else comes through the battery isolator then the fuse block.
panel is Aluminium engraved. cost about £50 online. toggle switches because I like them. They remind me of my old day job. :
very useful post!This is how my rotary nav light switch is wired which follows this colregs diagram. 3 way rotary switch that feeds 3 positive selections. The diode is a p600k wired inline. The 3 letters on left represent the selection Anchor, Sailing, Power and the 4 boxes represent anchor light, stern light, 2x bowlights, midmast light.
My anchor light also feeds marker lights set into the cabin sides but obviously these are not required.
so next question, where did you purchase or how have you built the panels?
for a simple application like a boat panel using different colours is way over the top - you'd end up with hundreds of tags left over.There is a proper international system of colors for different parts of the wiring
