Portofino
Ask the guy to do this - ? Simples
I'd expect it's neither. It will be weight, as in displacement. Neither nt nor grt are measures of weight, despite the use of the word "tonnage"
Actual mass of the boat or the GRT/NRT might have been better. The last boat I had lifted had a GRT of over 65 but actual weight on the lift was around 46 ton.
ok I get that aspect of your thinking ( though it isn't what you said!). Alas Deleted User is referring to weight not volume when he says his boat is 45 tonnes or whatever number he saidWhat I was suggesting is that the travel lift is rated in mass but the OP is using the GRT rather than the physical weight of the boat. (I think - been a long day!)
W.
Thanks Mike. My boat is obviously a bit shorter than yours but I think it's a bit beamier as well so I guess the weight won't be too far off what your P67 weighs. Whatever it actually weighs, it's close to 40t or just over by a few tonnes and therefore it's going to exceed the travelift capacity. Yup, good point about doubling up on the strops. I'll check with the yard I'm planning to take it to.
Anyway, under these conditions, the operator recons that she weighs in at 43T
I've always condidered that she is 50T - rounding up etc for safety.
So, in your case, it dhould be OK but I don't think I would take the risk.
Our yard also rigs double strops (4 in total) - I would have thought that would be prudent for yours as well.
Scuse the pedantry but mass and weight are different things. The relevant thing to a purist engineer here is weight not mass.
Ahem too!Ahem. If he says 25 tonnes he is referring to mass, not weight or volume!
My boat weighs 44t according to the manufacturer's technical data. I've always been a bit sceptical about whether it actually weighs this much because it's considerably more than any other boats of similar length from other manufacturers but if I take that figure as being accurate and add a couple of tons of fuel and another ton for the SWMBO's clothes and shoes, the boat weighs 47t. The marina where the boat is currently moored has a travelift gantry crane which has a max rated capacity of 40t. They're very keen to do the winter maintenance on my boat and they're insisting that they've lifted bigger and heavier boats than mine with this travelift and actually I have had this confirmed by somebody else in the marina. The nearest yard with a larger travelift is 60nm away and whilst I have made a provisional booking to have my boat lifted there, obviously it would be more convenient to have the boat lifted in my home marina.
What does the panel think? I haven't spoken to my insurance co yet but I think I know what they'll say
Mmmm... I wholeheartedly agree on your definition of "rough" for such measure of a boat displacement - much more so than the "within 10%" bit.If you take the water length of the vessel, times the beam and the sea water draught floating and multiply them together and then by 0.95 and 1.025 you will have a rough (within 10 per cent) estimate of the weight (displacement). This will give you the weight that has to be lifted.
Mariner69, thanks but that's not true. Broadly speaking there are 3 types of safety factor applied to lifting equipment, safety factors for overturning stability, safety factors for structural component failure and safety factors for lifting gear (ie ropes, chains, strops etc). It is true that safety factors for lifting gear are generally 5 but the two other safety factors can be much less. The minimum allowable safety factor for stability may be as low as 1.25 and for structural failure 1.5 although manufacturers may use more conservative figures than this. However to make a broad statement that a 100% overload is allowed as a one off for an emergency lift would be very dangerous for many types of lifting equipment.The lifting equipment should be marked with the Safe Working Load (SWL) which in the UK has a safety factor of 5 by law. Seamen making ad hoc lifts have traditionally used safety factors of 6 to be on the very safe side. An overload of 100 per cent (IIRC) is allowed fore a one off emergency lift on cranes but........... has to be recorded and can cause problems with HSE/MCA et al especially if it goes wrong. The owner of the lifting equipment takes the 'risks' and pays the consequences if it goes wrong so you should be interested in their insurance in the first instance.
Ahem too!![]()
. We both know what we mean
