Slowtack
FWIW I re-engined this last winter from VP2003 to D1-30. I installed myself and the dealer included an inspection for the warranty.
So far so good..............
To me, everything else being equal, I'd go the Volvo route with the bigger alternator. I believe that Parkinson's Marine Law that - 'power requirement grow to just exceed the ability to produce that power' is valid and the rate of increased power requirements is growing (as we carry iPads, cameras, phones - in addition to all the instrumentation). Being able to recharge quickly is an asset our of proportion to any likely differences in cost.
Jonathan
I have no knowledge of either engine but I would go for one without an electronic control box if possible. Saw a chap trying to start a diesel van this week. Bled satisfactorily but wouldn't go. Mechanic said it's either this electronic box, the cheaper one or that which costs more than the van is worth! If the electronic control box fails at sea through penetration of salt water there is nothing you can do apart from sail or call the lifeboat, if you don't carry a spare.
In all likelihood a relatively modest alternator of 60-70amps will be able to supply current at a greater rate than the batteries can accept unless the OP has a particularly large battery bank, or is using some chemistry like Lithium.
Its becoming habitual that I answer and then delete my post
I can assure you that charging a 400 amp house battery bank with 2 x 60 amp alternators takes a long time. A 120 amp alternator would be a boon. From memory you need to run the older engines quite fast to get the 60 amps but the new Volvos s]charge at maximum amps at much lower revs.
Maybe you would like to post how exactly you do this. Start with the Volvo D2 series of engines please!You can start a marine diesel engine of the sophistication of the sort we all use by shorting out the control box, electronic or not. All you need it a screw driver and know which terminals to short. Everyone should know how to do it - its easy, a few seconds, and any diesel mechanic can tell you how to do it. To call our a lifeboat is simply daft and incompetence. You also need to stop manually - but that is equally easy.
Tranona,
But your D1/30 has a 120 amp alternator - surely a 30hp (auxiliary) engine and a bow thruster on a 33' yacht is OTT
Jonathan
I have a new D1-20 on a pallet , PRM 2-1 gearbox with large alternator , electronic panel replaced with conventional gauges and loom . engine is now surplus to requirements , PM me if its of interest .
For my education
Why has the electronic panel been replaced with conventional gauges and loom - and what gauges? Does this encompass the relay box - interested in the reasons.
Jonathan
Thanks Peter,
I need to get out more.
I knew Volvo had done away with the relay box with relays and replaced it with, what they call a 'relay box' without relays! I had not realised they had tarted up the display, or controls with lots of meters - I thought it was the same as the old MD series with coloured lights and one alarm but with automatic glow and 'electronic' start and stop. We have a boat show in 3 weeks I'll go and have a gander. But VDO - expensive and, I agree, OTT for a bog standard 20hp engine.
Jonathan
