fergusT
New Member
Hi All,
I am hoping that someone will be able to settle my mind. I have a new (used) boat in Spain. It is an open day boat (quick silver 500) and has been kept in a garage and mostly launched and recovered. So the bottom has never been anti-fouled and is very clean.
I will keep the boat in the water for maximum 14 weeks, but that will include 3-4 week stretches when it is back in dry store. The longest time it will be in the water for will be around 6 weeks and more often it will be for 15-18 days at a time.
When in the water the boat will be on a swing mooring in an estuary that has strong tidal flows and a lot of vegetation and stuff is sweep along with each tide. The mooring pier is covered in mussels.
Should I anti-foul the bottom is my dilema. I think now is the time to do it, when it is clean and it is in the boat yard, so easy to do. Then I remember that I have read that you need to have the boat in the water for the anti-foul to go off. So I should not do it until I am about to put it in the water, but it will only be in the water for a week or so before being taken out and back to the boat yard.
Then I think, is it really necessary. If it is most often in for two weeks and then out, jet washed, scrubbed if necessary and keep in the boat yard until next use, which will be 3-4 weeks time, is it necessary to anti-foul with primer and then top coat.
So is there anyone else out there thatis having similar use of their boat in the med area that could offer some advice and let me sleep at night?
Many thanks,
Many thanks,
