DaveS
Sort of repeating what has already been said, but I was recently advised by a very experienced skipper who sails single handed as follows:
Make up a line with a LARGE bowline loop for hooking over the cleat at the end of the finger. The other should already be attached (by another bowline) to the centre cleat on the boat. The line should be the exact length to stop the boat hitting the pontoon, and should include a snubber to absorb the forward momentum.
As you pass the end finger cleat, pop the large bowline over it and let the boat pull itself gently alongside. Leave the engine ticking over in forward gear to keep the boat pinned to the finger whilst you disembark and make secure.
Now, I haven't tried it myself, but it seems like a good plan, and I will be making up said line - hopefully it will prevent the crew having to jump off with lines whilst not fully alongside.
Any thoughts?
I use a similar system, but with a couple of additions: I've a bit of plastic hose round the loop to hold it open, and a second line attached to the loop and held on the stern cleat. The latter is left with sufficient slack that the pontoon cleat can be reached at full stretch, but sufficiently short that my stern will not hit my neighbour if the stern drifts off. After other lines are attached I pull the stern line in till the boat's in its final position.
For a short finger the whole arrangement could be moved forward to bow and centre cleats, but single handing might be difficult.
