Hurricane
It's amazing how bad electrical supplies are at marinas.
Having had problems in the past, I always now check a shore supply before plugging in.
Recently, we were given (had to rent) a connector at a marina that picked off one of the three pase supply using a prewired short length of flex that we were supposed to connect onto. I always keep spare connectors so connected up and got some very strange readings from my multimeter. After a lot of fiddling around, it turned out that the flex had been previously overloaded and some of the cables were fused together.
On a recent trip up the Spanish coast, we tested the shore supply before connecting - in three days, we used three different marinas with three different polarities of shore supply.
I use a cheap multimeter and check that I there is 230v between Line and Neutral - 230v between Line and Ground (Earth) - and very little voltage between Neutral and Ground. This technique also spots any pahse to phase problems - yep - been there - had one of those as well!!!
Testing is a bit of a pain. I usually check the supply at the (boat's) end of my own leads so it means holding the sprung flap open and shoving the multimeter's probes in - they often dont make very good connection.
So, I wondered if there was anything out there that tests the supply thoroughly. There are lots of plug in ring main testers but most of them dont say what they actually testing for. And those that do say, dont seem to test for earth polarity reversal.
Our boat does have a couple of neons connected to check the line and neutral voltage polarity but thats all.
I'm tempted to make a little box with three voltmeters but it does seem a bit overkill.
Does anyone have any good solutions?
