Shore power stanchion (?)
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
I recently suggested to my club that they install a couple of these on one of the pontoons.
The suggestion was declined citing cost of the unit and the installation thereof.
I have tried to find a source of the unit that is fitted with the meters and outlets but know neither the correct name nor a suppliers.
Anyone help please?
starfire
7 May 2005
Not In the Med
Stemar
12 Sep 2001
It isn't just the posts on the pontoons, it's the system to charge users. Either that, or you'll have people running electric heaters and induction hobs, plus all the other mains stuff that we clutter up our boats with. Then there's That Guy, with his electric boat and 1200AH of batteries that need charging... Just ask the Hardway management committee.
OK, I made That Guy up, but you know what I mean.
We'd been going through that over the last couple of years using a smart card system. Now people grumble that there aren't enough points, but more would require upgrading the supply to the club, which is silly money.
Neeves
20 Nov 2011
Sydney, Australia.
Common in caravan sites though charging by a meter is not common, you just pay a lump sum for power, water and sometimes black water.
So visit a caravan site and check the manufacturer's labels on the posts. One, cheap?, way to limit usage is to add a circuit breaker.
Refueler
13 Sep 2008
Far away from hooray henrys
At Milford Haven marina it was (is?) compulsory for power users to purchase an online meter and display it. Yard staff would check consumption regularly.
Many marinas I knew off - insisted you buy the meter from them ... and if you left that marina permanently - to sell it back to them.
Just a point to 'others' - don't forget to NOT use that same metered lead when visiting another marina etc - as the meter will tot up and when you get back to home berth - you could end up paying again !!
Refueler
13 Sep 2008
"penberth3" .. I know it sounds daft - but I know people this happened to ...
They took their metered lead with them - plugged in at next stops ... meter kept counting .... then back to home marina - plugged in ... when they got bill later - the consumption at other marinas was part of the tally at home marina ... when queried with marina - they just said - meter says XXX - we charge XXX less previous meter reading YYY ....
