We have a Dahler 36 CWS. We have just discovered that the shore earth is connected to the battery positive output inside the charger. This results in 14 V DC between the calorifier with shore powered immersion heater and the diesel tank. This would not normally be a problem until you try and remove a valve from the calorifier and touch the diesel tank with the spanner!!! The question is: Why is the shore earth connected to the 14V positive output inside the charger? Should it be connected to the 14V negative output so that the boat ground is at shore earth? That is how I read the diagram in last months PBO?
