TheMarketMech
Hi all, I'm new to the site. I've just bought a shetland 460, plate number 263. I knew it needed work prior to buying and I want to get my hands dirty. As per title the transom is rotten, and the buoyancy foam under the deck is soaking wet. Ive started to remove the transom. The box part of the transom is 18mm marine ply which I don't think I'll have too much of a problem with. The wood glassed in at the hull (where outboard clamps too), measures 27mm thickness. So I thought maybe to replace that by using 3 x 9mm marine plywood to glass in? As from what I've researched, multiple layers of ply are better than one thick piece.
My main concern is the deck and where to cut and how to go about repairing it... do i use foam and replace like for like? Or do I go down the play pit ball/empty plastic bottle route? Where do I cut? Do I reuse the original deck or am I completely glassing in some marine ply? I've attached a picture showing the deck, transom is already removed. Thanks. Chris.
